Introdução
This guide will show you how to replace the micro-USB type B port on the side of the Sony Cyber-shot DSC-F717’s rotating lens body. While this repair has a very simple procedure to fix, there are several factors to take into consideration when performing the repair. These factors include making sure not to damage the exposed circuitry and making sure that there is no power in the camera.
Be sure to remove the the battery before beginning to prevent damage to the camera.
O que você precisa
Remove the three screws from the side of the lens using a JIS #000 screwdriver.
Remove the longer single screw from the bottom of the lens using a JIS #000 screwdriver.
