Introdução
This guide will help you to replace the lens assembly on the Sony Cyber Shot DSC-W170.
If the camera lens is cracked or otherwise damaged, the solution is to replace the camera lens.
Be careful when removing shattered glass displays, be sure to remove power/disconnect batteries ,and take a look at the ESD-safe tools website before performing this task!
A necessary skill is to be able to use a soldering iron.
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
O que você precisa
Remove the first side panel to the left of the LCD.
Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
Desolder the wires connecting the top panel circuit board from the lens with the soldering iron.
