Ir para o conteúdo principal
Sony CFD-8 Battery Replacement
  1. Sony CFD-8 Battery Replacement, Battery: passo 1, imagem 1 %32 Sony CFD-8 Battery Replacement, Battery: passo 1, imagem 2 %32 Sony CFD-8 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
    Pergunte ao FixBot
    Comentar
  2. Sony CFD-8 Battery Replacement: passo 2, imagem 1 %32 Sony CFD-8 Battery Replacement: passo 2, imagem 2 %32
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
    Pergunte ao FixBot
    Comentar
Conclusão
Tess
Membro desde: 10/14/14
439 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-38, Amido Fall 2014 Membro de Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 35
Ao todo: 1,889
