Ir para o conteúdo principal
Sony CDX-GT540UI Fuse Replacement
    1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: passo 1, imagem 1 %32
      • Locate the clip on the wiring harness.
      Pergunte ao FixBot
      Comentar
    2. Sony CDX-GT540UI Fuse Replacement: passo 2, imagem 1 %32 Sony CDX-GT540UI Fuse Replacement: passo 2, imagem 2 %32
      • Press down on the clip like you would an Ethernet cable.
      • Rock harness side to side, pulling gently towards you until harness detaches.
      Pergunte ao FixBot
      Comentar
    1. Sony CDX-GT540UI Fuse Replacement, Fuse: passo 3, imagem 1 %32
      • Once you have removed the wiring harness.
      • Locate the fuse.
      Pergunte ao FixBot
      Comentar
    2. Sony CDX-GT540UI Fuse Replacement: passo 4, imagem 1 %32
      • Using your index finger and thumb on either side of the fuse.
      Pergunte ao FixBot
      Comentar
    3. Sony CDX-GT540UI Fuse Replacement: passo 5, imagem 1 %32
      • Rock back and forth gently pulling towards yourself until the fuse is removed.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Odelkys Marquez
Membro desde: 09/22/14
1.139 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 10-2, Brown Fall 2014 Membro de USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Membros
Autoria de 7 guias
1Comentário do guia
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 64
Ao todo: 10,681
