Ir para o conteúdo principal
Sony BDP-s7200 Disk Drive Replacement
O que você precisa
  1. Sony BDP-s7200 Disk Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the disk tray cover from the device.
    Pergunte ao FixBot
  2. Sony BDP-s7200 Disk Drive Replacement: passo 2, imagem 1 %32 Sony BDP-s7200 Disk Drive Replacement: passo 2, imagem 2 %32
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
    Pergunte ao FixBot
  3. Sony BDP-s7200 Disk Drive Replacement: passo 3, imagem 1 %32 Sony BDP-s7200 Disk Drive Replacement: passo 3, imagem 2 %32
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
    Pergunte ao FixBot
  4. Sony BDP-s7200 Disk Drive Replacement: passo 4, imagem 1 %32
    • Pull off the back panel and remove it from the device.
    Pergunte ao FixBot
  5. Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: passo 5, imagem 1 %32 Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: passo 5, imagem 2 %32 Sony BDP-s7200 Disk Drive Replacement, Front Panel Cover: passo 5, imagem 3 %32
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
    Pergunte ao FixBot
  6. Sony BDP-s7200 Disk Drive Replacement: passo 6, imagem 1 %32 Sony BDP-s7200 Disk Drive Replacement: passo 6, imagem 2 %32
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
    Pergunte ao FixBot
  7. Sony BDP-s7200 Disk Drive Replacement: passo 7, imagem 1 %32 Sony BDP-s7200 Disk Drive Replacement: passo 7, imagem 2 %32 Sony BDP-s7200 Disk Drive Replacement: passo 7, imagem 3 %32
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
    Pergunte ao FixBot
  8. Sony BDP-s7200 Disk Drive Replacement: passo 8, imagem 1 %32 Sony BDP-s7200 Disk Drive Replacement: passo 8, imagem 2 %32
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
    Pergunte ao FixBot
  9. Sony BDP-s7200 Disk Drive Replacement, Disk Drive: passo 9, imagem 1 %32 Sony BDP-s7200 Disk Drive Replacement, Disk Drive: passo 9, imagem 2 %32
    • Using the Phillips #2 Screwdriver, unscrew the four 9mm screws from disk drive.
    • Disconnect the 3 ribbon cables connecting the disk drive to the motherboard
    • Pull the disk drive from the device to remove it.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 1,086
