Ir para o conteúdo principal
Sony BDP-S3500 Disk Drive Replacement
O que você precisa
  1. Sony BDP-S3500 Disk Drive Replacement, Front Panel: passo 1, imagem 1 %32 Sony BDP-S3500 Disk Drive Replacement, Front Panel: passo 1, imagem 2 %32
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
    Pergunte ao FixBot
  2. Sony BDP-S3500 Disk Drive Replacement: passo 2, imagem 1 %32
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
    Pergunte ao FixBot
  3. Sony BDP-S3500 Disk Drive Replacement: passo 3, imagem 1 %32 Sony BDP-S3500 Disk Drive Replacement: passo 3, imagem 2 %32
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
    Pergunte ao FixBot
  4. Sony BDP-S3500 Disk Drive Replacement, Disk Drive: passo 4, imagem 1 %32 Sony BDP-S3500 Disk Drive Replacement, Disk Drive: passo 4, imagem 2 %32
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
    Pergunte ao FixBot
  5. Sony BDP-S3500 Disk Drive Replacement: passo 5, imagem 1 %32 Sony BDP-S3500 Disk Drive Replacement: passo 5, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
    Pergunte ao FixBot
  6. Sony BDP-S3500 Disk Drive Replacement: passo 6, imagem 1 %32 Sony BDP-S3500 Disk Drive Replacement: passo 6, imagem 2 %32
    • Carefully lift and slide the disk drive out of the casing.
    Pergunte ao FixBot
Conclusão
V W
Membro desde: 01/22/20
197 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
Hello, great guide thank you. How do you go about finding the correct replacement drive?
Andy Day - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 48
Ao todo: 774
