Ir para o conteúdo principal
Sony BDP-S1 Fan Replacement
O que você precisa
  1. Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: passo 1, imagem 1 %32 Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: passo 1, imagem 2 %32
    • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
    • Don't forget, there are two more 12mm screws on the other side as well.
    Pergunte ao FixBot
    Comentar
  2. Sony BDP-S1 Fan Replacement: passo 2, imagem 1 %32 Sony BDP-S1 Fan Replacement: passo 2, imagem 2 %32 Sony BDP-S1 Fan Replacement: passo 2, imagem 3 %32
    • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
    • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
    • Lastly, remove the three 12mm black screws on each side of device.
    Pergunte ao FixBot
    Comentar
  3. Sony BDP-S1 Fan Replacement: passo 3, imagem 1 %32 Sony BDP-S1 Fan Replacement: passo 3, imagem 2 %32 Sony BDP-S1 Fan Replacement: passo 3, imagem 3 %32
    • Potential for device damage: Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
    • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
    Pergunte ao FixBot
    Comentar
  4. Sony BDP-S1 Fan Replacement: passo 4, imagem 1 %32 Sony BDP-S1 Fan Replacement: passo 4, imagem 2 %32 Sony BDP-S1 Fan Replacement: passo 4, imagem 3 %32
    • After the top is off, you'll see that there are two metal bars that go across the top of the device.
    • Remove each bar by unscrewing the two 10mm silver screws on each end.
    Pergunte ao FixBot
    Comentar
  5. Sony BDP-S1 Fan Replacement, Fan: passo 5, imagem 1 %32 Sony BDP-S1 Fan Replacement, Fan: passo 5, imagem 2 %32 Sony BDP-S1 Fan Replacement, Fan: passo 5, imagem 3 %32
    • First we need to unscrew the fan from before we can remove it.
    • Remove both copper colored 10mm screws with a #2 phillips screwdriver.
    • As you remove the second screw, pull the fan inward to remove it from the remainder of the case. It should now only be connected to the case through a cable attached to the circuit board.
    • The disk drive is removed in the pictures, however this is not necessary to replace the fan and can be ignored.
    Pergunte ao FixBot
    Comentar
  6. Sony BDP-S1 Fan Replacement: passo 6, imagem 1 %32 Sony BDP-S1 Fan Replacement: passo 6, imagem 2 %32 Sony BDP-S1 Fan Replacement: passo 6, imagem 3 %32
    • We will now completely remove the fan from the player.
    • Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
    • You are now ready to install the new fan!
    Pergunte ao FixBot
    Comentar
Conclusão
Nicolas Kennedy
Membro desde: 01/26/14
111 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 9-30, Maness Winter 2014 Membro de Cal Poly, Team 9-30, Maness Winter 2014
CPSU-MANESS-W14S9G30
3 Membros
Autoria de 5 guias
2Comentários do guia
We're can i get a replacement fan for my Blu- ray player model BDV-E4100. HEEEEELP PLEASE.
darren cottenham - Responder Compartilhar
Where can I get a replacement fan for my blue-ray player.
Christopher Meriweather - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 49
Ao todo: 3,251
