Ir para o conteúdo principal
Sony BDP-BX520 Disc Tray Replacement
O que você precisa
  1. Sony BDP-BX520 Disc Tray Replacement, Disc Tray Cover: passo 1, imagem 1 %32
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
    Pergunte ao FixBot
    Comentar
  2. Sony BDP-BX520 Disc Tray Replacement: passo 2, imagem 1 %32
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
    Pergunte ao FixBot
    Comentar
  3. Sony BDP-BX520 Disc Tray Replacement: passo 3, imagem 1 %32
    • Close the disc tray, then power off and unplug the Blu-Ray player.
    Pergunte ao FixBot
    Comentar
  4. Sony BDP-BX520 Disc Tray Replacement, Top Case: passo 4, imagem 1 %32
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
    Pergunte ao FixBot
    Comentar
  5. Sony BDP-BX520 Disc Tray Replacement: passo 5, imagem 1 %32 Sony BDP-BX520 Disc Tray Replacement: passo 5, imagem 2 %32
    • Gently pull the top case back to remove it from the Blu-Ray player.
    Pergunte ao FixBot
    Comentar
  6. Sony BDP-BX520 Disc Tray Replacement, Front Panel: passo 6, imagem 1 %32
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
    Pergunte ao FixBot
    Comentar
  7. Sony BDP-BX520 Disc Tray Replacement: passo 7, imagem 1 %32
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
    Pergunte ao FixBot
    Comentar
  8. Sony BDP-BX520 Disc Tray Replacement: passo 8, imagem 1 %32
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
    Pergunte ao FixBot
    Comentar
  9. Sony BDP-BX520 Disc Tray Replacement: passo 9, imagem 1 %32 Sony BDP-BX520 Disc Tray Replacement: passo 9, imagem 2 %32
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
    Pergunte ao FixBot
    Comentar
  10. Sony BDP-BX520 Disc Tray Replacement, Disc Tray: passo 10, imagem 1 %32 Sony BDP-BX520 Disc Tray Replacement, Disc Tray: passo 10, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the two silver 8 mm screws on the right side of the disk tray .
    Pergunte ao FixBot
    Comentar
  11. Sony BDP-BX520 Disc Tray Replacement: passo 11, imagem 1 %32 Sony BDP-BX520 Disc Tray Replacement: passo 11, imagem 2 %32
    • Pull the medium-sized 9 pin ribbon cable out of its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  12. Sony BDP-BX520 Disc Tray Replacement: passo 12, imagem 1 %32 Sony BDP-BX520 Disc Tray Replacement: passo 12, imagem 2 %32 Sony BDP-BX520 Disc Tray Replacement: passo 12, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, lift up the tab of the large 45 pin connector on the motherboard.
    • Pull the large 45 pin ribbon cable out of its connector.
    Pergunte ao FixBot
    Comentar
  13. Sony BDP-BX520 Disc Tray Replacement: passo 13, imagem 1 %32 Sony BDP-BX520 Disc Tray Replacement: passo 13, imagem 2 %32
    • Pull the small 5 pin ribbon cable out of its connector on the motherboard.
    Pergunte ao FixBot
    Comentar
  14. Sony BDP-BX520 Disc Tray Replacement: passo 14, imagem 1 %32 Sony BDP-BX520 Disc Tray Replacement: passo 14, imagem 2 %32
    • Slide the disk tray out from under the tabs on the case holding it down while lifting it out of the case.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 8-41, Amido Winter 2015 Membro de Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 Membros
Autoria de 8 guias
3Comentários do guia
Thanks, this helped a lot. I still cant get the DVD drawer to eject with the eject button. The power light will not turn off.
tomcerecedes - Responder Compartilhar
Thank you thank you thank you. I spent an hour on the phone with Sony “technical support “ and was told nothing could be done except to send it off for servicing. This worked PERFECTLY!!!! THANKS AGAIN ?
Susan Brown - Responder Compartilhar
Cómo retiro la charola del disco
Anuar - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 50
Ao todo: 8,045
