Ir para o conteúdo principal
Sony BDP BX350 Device Control Board Replacement
O que você precisa
  1. Sony BDP BX350  Device Control Board Replacement, Control Board: passo 1, imagem 1 %32
    • Remove the three 10mm Philips head screws on the back of the player.
    Pergunte ao FixBot
    Comentar
  2. Sony BDP BX350  Device Control Board Replacement: passo 2, imagem 1 %32
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
    Pergunte ao FixBot
    Comentar
  3. Sony BDP BX350  Device Control Board Replacement: passo 3, imagem 1 %32
    • Lift the tabs located on each side of the device to free the front cover. Begin separating the two covers from metal casing.
    Pergunte ao FixBot
    Comentar
  4. Sony BDP BX350  Device Control Board Replacement: passo 4, imagem 1 %32
    • Remove both covers.
    Pergunte ao FixBot
    Comentar
  5. Sony BDP BX350  Device Control Board Replacement: passo 5, imagem 1 %32 Sony BDP BX350  Device Control Board Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Do not bend or tear the ribbon cable.
    • Using the plastic tweezers, carefully remove the ribbon cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Sony BDP BX350  Device Control Board Replacement: passo 6, imagem 1 %32
    • Unscrew the one 5mm Phillips head screw from the front of the device board.
    Pergunte ao FixBot
    Comentar
  7. Sony BDP BX350  Device Control Board Replacement: passo 7, imagem 1 %32 Sony BDP BX350  Device Control Board Replacement: passo 7, imagem 2 %32
    • Do not bend or tear ribbon cable.
    • Carefully separate the device control board from the metal casing.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 725
