Ir para o conteúdo principal
Sony Alpha NEX-6 Lens Mount Replacement
O que você precisa
    1. Sony Alpha NEX-6 Lens Mount Replacement, Finding the Release Button: passo 1, imagem 1 %32
      • Turn the camera with the lens facing up.
      • Find the lens release button - located along the side of the silver lens mount.
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: passo 2, imagem 1 %32 Sony Alpha NEX-6 Lens Mount Replacement, Removing the Lens: passo 2, imagem 2 %32
      • Press and hold the lens release button while rotating the lens counterclockwise.
      • Lift the lens when it is no longer attached to the camera.
      • To replace the lens, align the white dot on the lens with the white dot located on the silver lens mount. (See image two)
      • Insert the lens and rotate it clockwise until it is locked in place.
      Pergunte ao FixBot
      Comentar
    1. Sony Alpha NEX-6 Lens Mount Replacement, Lens Mount: passo 3, imagem 1 %32
      • While dealing with this guide, do not touch the delicate image sensor (the center rectangle encircled by the lens mount).
      • After removing the lens, you will come into contact with the lens mount. Start by unscrewing the four 3.5 mm Phillips #00 screws.
      • The outer lens mount ring can now be removed.
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha NEX-6 Lens Mount Replacement: passo 4, imagem 1 %32 Sony Alpha NEX-6 Lens Mount Replacement: passo 4, imagem 2 %32 Sony Alpha NEX-6 Lens Mount Replacement: passo 4, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Pay attention to the positioning of the spacer rings for reassembly.
      • For the first (black) spacer ring, use the tweezers to gently pry the ring out of place.
      • Repeat this step for the second (silver) spacer ring.
      • The third image is what the camera should look like after all spacer rings are removed.
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha NEX-6 Lens Mount Replacement: passo 5, imagem 1 %32 Sony Alpha NEX-6 Lens Mount Replacement: passo 5, imagem 2 %32
      • To remove the inner lens mount ring, remove the two silver 2.0 mm Phillips #00 screws. This will complete the removal of the lens mount.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Clayton Dale
Membro desde: 01/20/15
1.067 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro de USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 45
Ao todo: 2,214
