Ir para o conteúdo principal
Sony Alpha NEX-6 Battery Replacement
O que você precisa
    1. Sony Alpha NEX-6 Battery Replacement, Battery: passo 1, imagem 1 %32
      • Prior to operating on this device, be sure the camera is turned OFF. With power, the camera can be a dangerous device to work with.
      • Turn the camera off by switching the power knob "OFF" text to the white selector dot.
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha NEX-6 Battery Replacement: passo 2, imagem 1 %32
      • Flip the camera upside-down and carefully place it on a flat surface.
      • With the lens facing outward, locate the battery compartment - indicated by a grooved latch.
      • Push the latch to the right to unlock the battery compartment. The door should flip upward.
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha NEX-6 Battery Replacement: passo 3, imagem 1 %32
      • With the compartment open, locate a blue tab shown with spudger
      • Press the tab to the side (to the left, or toward the camera wall). This will eject the camera battery.
      Pergunte ao FixBot
      Comentar
Conclusão
Clayton Dale
Membro desde: 01/20/15
1.067 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 11-2, Blackwell Winter 2015 Membro de USF Tampa, Team 11-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G2
4 Membros
Autoria de 14 guias
3Comentários do guia
Battery Stuck
rustychinnis - Responder Compartilhar
Will not spring out. Any ideas?
Got it, battery damaged. Tapped on edge to remove battery
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 3,046
