Ir para o conteúdo principal
Sony Alpha NEX-5N Lens Release Button Replacement
O que você precisa
  1. Sony Alpha NEX-5N Lens Release Button Replacement, E-mount: passo 1, imagem 1 %32 Sony Alpha NEX-5N Lens Release Button Replacement, E-mount: passo 1, imagem 2 %32
    • While completing this guide, do not touch the image sensor (the center rectangle encircled by the lens mount).
    • Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
    • Applying extra force to unscrew these 4 screws may be necessary.
    • Detach the outer lens mount ring.
  2. Sony Alpha NEX-5N Lens Release Button Replacement: passo 2, imagem 1 %32 Sony Alpha NEX-5N Lens Release Button Replacement: passo 2, imagem 2 %32
    • Pay attention to the positioning and order of the spacing rings for reassembly.
    • Using your fingers, pull out the first black spacer ring.
    • Repeat the previous step for the second silver spacer ring.
  3. Sony Alpha NEX-5N Lens Release Button Replacement: passo 3, imagem 1 %32 Sony Alpha NEX-5N Lens Release Button Replacement: passo 3, imagem 2 %32 Sony Alpha NEX-5N Lens Release Button Replacement: passo 3, imagem 3 %32
    • Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
    • Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
    • The lens release button and the small spring underneath will be loose.
  4. Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: passo 4, imagem 1 %32 Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: passo 4, imagem 2 %32 Sony Alpha NEX-5N Lens Release Button Replacement, Lens Release Button: passo 4, imagem 3 %32
    • Find the lens release button.
    • The button should be easily removed by hand.
  5. Sony Alpha NEX-5N Lens Release Button Replacement: passo 5, imagem 1 %32
    • After removing the button, the spring underneath it is uncovered and can be replaced.
    • This completes the removal of the lens release button.
Conclusão
Anna Tole
Membro desde: 09/28/15
191 Reputação
Autoria de 1 guia
Um comentário
What to do if the lens is attached to the camera and the release button is stuck?
on a Nikon d7100.
ajbakh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 20
Duração total: 1,905
