Introdução
Your camera is a marvel of modern technology but a tiny rock or a stick can ruin it all. Don't let that happen to you. This viewfinder window is there to protect the more delicate optics behind the cover and is designed to take the hit so the more expensive pieces do not become damaged. Use this guide to replace this piece if you have damaged it accidently. If you damaged it on purpose... well... ok it is your camera whatever floats your boat man; you can still use this guide to replace the part however.
O que você precisa
Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
