Ir para o conteúdo principal
Sony Alpha DSLR- A850 Viewfinder Cover Replacement
O que você precisa
    1. Sony Alpha DSLR- A850 Viewfinder Cover Replacement, Viewfinder Cover: passo 1, imagem 1 %32
      • Find the rubber viewfinder cover on the upper rear of the camera, above the view screen.
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha DSLR- A850 Viewfinder Cover Replacement: passo 2, imagem 1 %32
      • Slide the rubber piece off.
      • There may be a slight popping sound.
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha DSLR- A850 Viewfinder Cover Replacement: passo 3, imagem 1 %32
      • Once the rubber piece has been removed, inspect the area.
      • If everything looks fine, go ahead and slide the new rubber piece on the same way the old piece was slipped off.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 27
Ao todo: 820
