Ir para o conteúdo principal
Sony Alpha DSLR- A850 Focusing Screen Replacement
O que você precisa
    1. Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: passo 1, imagem 1 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: passo 1, imagem 2 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement, Focusing Screen: passo 1, imagem 3 %32
      • Push in the button next to the lens.
      • While holding the button twist the lens counter-clockwise.
      • Pull up and remove lens from camera.
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 2, imagem 1 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 2, imagem 2 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 2, imagem 3 %32
      • Inside toward the top you will find a small slit in the plastic piece.
      • Insert a flat head screw driver into the slit and pull down to access the focusing screen.
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 3, imagem 1 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 3, imagem 2 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 3, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Using tweezers grab the focusing screen on the side by the two tabs that are on it.
      • Do not grab the focusing screen in the middle as this will damage it.
      • Pull out and remove focusing screen from camera.
      Pergunte ao FixBot
      Comentar
    4. Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 4, imagem 1 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 4, imagem 2 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 4, imagem 3 %32
      • When inserting new screen make sure to orient it where the two tabs are facing towards you with the smaller tab facing up.
      • Angle the focusing screen to make installation easier.
      • Lay the new focusing screen into the plastic tray.
      • It does not snap into place.
      Pergunte ao FixBot
      Comentar
    5. Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 5, imagem 1 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 5, imagem 2 %32
      • Insert screw driver into the slit and push up to close.
      • You can also use your thumb, if you are careful not to touch the screen as this could leave a smudge on it.
      • You will hear a click when the plastic tray is back in place.
      Pergunte ao FixBot
      Comentar
    6. Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 6, imagem 1 %32 Sony Alpha DSLR- A850 Focusing Screen Replacement: passo 6, imagem 2 %32
      • When re-installing the lens line up the orange dots that are one both lens and camera.
      • Fit lens into place and turn clockwise to secure it back to camera.
      Pergunte ao FixBot
      Comentar
Conclusão
You have now completed a focusing screen replacement.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 50
Ao todo: 1,421
