Ir para o conteúdo principal
Sony Alpha A3000 Motherboard Replacement
O que você precisa
    1. Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, imagem 2 %32 Sony Alpha A3000 Motherboard Replacement, Rear Case: passo 1, imagem 3 %32
      • Remove the seven highlighted screws shown here.
      • Screws are teeny tiny, don't lose them!
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha A3000 Motherboard Replacement: passo 2, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 2, imagem 2 %32
      • Remove this final screw from the memory card compartment.
      • Remove the chassis by pulling the back cover away from the camera.
      • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha A3000 Motherboard Replacement: passo 3, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 3, imagem 2 %32
      • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
      Pergunte ao FixBot
      Comentar
    1. Sony Alpha A3000 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32
      • After removing the backing from the camera. Remove the two final screws in the memory compartment area.
      • Detach the facing for the memory dock.
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha A3000 Motherboard Replacement: passo 5, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 5, imagem 2 %32
      • Remove the eight screws securing the mount for the flash device.
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha A3000 Motherboard Replacement: passo 6, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 6, imagem 2 %32
      • Remove the three remaining screws holding in the protective metal casing.
      Pergunte ao FixBot
      Comentar
    4. Sony Alpha A3000 Motherboard Replacement: passo 7, imagem 1 %32
      • Remove the metal casing.
      Pergunte ao FixBot
      Comentar
    5. Sony Alpha A3000 Motherboard Replacement: passo 8, imagem 1 %32
      • Remove three screws holding down the motherboard .
      Pergunte ao FixBot
      Comentar
    6. Sony Alpha A3000 Motherboard Replacement: passo 9, imagem 1 %32 Sony Alpha A3000 Motherboard Replacement: passo 9, imagem 2 %32
      • Detach the nine serial cables connecting it to the camera body.
      Pergunte ao FixBot
      Comentar
    7. Sony Alpha A3000 Motherboard Replacement: passo 10, imagem 1 %32
      • Finally remove the motherboard from the casing.
      Pergunte ao FixBot
      Comentar
Conclusão
8 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 4-4, Meier Fall 2015 Membro de USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Membros
Autoria de 10 guias
1Comentário do guia
Then loose the plug all the motherboard?
kongre172 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 50
Ao todo: 3,218
