Ir para o conteúdo principal
Sony Alpha 6000 Shutter Button Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
    1. Sony Alpha 6000 Shutter Button Replacement, Battery: passo 1, imagem 1 %32
      • Make sure the camera is turned off by turning the switch to OFF.
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha 6000 Shutter Button Replacement: passo 2, imagem 1 %32
      • Flip the camera around to access the battery compartment.
      • Slide the battery compartment lock to the left to unlock it.
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha 6000 Shutter Button Replacement: passo 3, imagem 1 %32
      • Locate the blue latch that holds the battery in.
      Pergunte ao FixBot
      Comentar
    4. Sony Alpha 6000 Shutter Button Replacement: passo 4, imagem 1 %32
      • Push the latch back to release battery.
      Pergunte ao FixBot
      Comentar
    5. Sony Alpha 6000 Shutter Button Replacement: passo 5, imagem 1 %32
      • The battery can now be taken out of its compartment.
      Pergunte ao FixBot
      Comentar
    1. Sony Alpha 6000 Shutter Button Replacement, Back Cover: passo 6, imagem 1 %32
      • Turn the camera upside down and unscrew these two bottom 6 mm screws located on either side of the body by using the J00 head screw.
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha 6000 Shutter Button Replacement: passo 7, imagem 1 %32
      • Turn the camera sideways.
      • Open the mini HDMI compartment and locate the two 6 mm screw underneath and another to the right of the compartment.
      • Unscrew using the J00 head screw.
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha 6000 Shutter Button Replacement: passo 8, imagem 1 %32
      • Locate the two 4 mm screws within the battery compartment and unscrew them using the J00 screw head.
      Pergunte ao FixBot
      Comentar
    4. Sony Alpha 6000 Shutter Button Replacement: passo 9, imagem 1 %32
      • Bend the camera's screen forward to uncover two 3 mm screws below the eyepiece.
      • Locate them and unscrew them.
      Pergunte ao FixBot
      Comentar
    5. Sony Alpha 6000 Shutter Button Replacement: passo 10, imagem 1 %32 Sony Alpha 6000 Shutter Button Replacement: passo 10, imagem 2 %32
      • Use a plastic opening tool around the body of the camera to wedge the back cover off. Start from the bottom next to the battery compartment.
      • If necessary, lightly use your hand to pull the the back cover down to completely remove it.
      Pergunte ao FixBot
      Comentar
    1. Sony Alpha 6000 Shutter Button Replacement, Shutter Button: passo 11, imagem 1 %32
      • Once the back cover is off, locate the flash of the camera and push it forward to open it
      Pergunte ao FixBot
      Comentar
    2. Sony Alpha 6000 Shutter Button Replacement: passo 12, imagem 1 %32
      • Locate the two 3 mm screws within the flash and unscrew them
      Pergunte ao FixBot
      Comentar
    3. Sony Alpha 6000 Shutter Button Replacement: passo 13, imagem 1 %32
      • Hold the camera from the bottom and using a spudger, go around the top of the camera and separate the top plastic piece from the main body.
      Pergunte ao FixBot
      Comentar
    4. Sony Alpha 6000 Shutter Button Replacement: passo 14, imagem 1 %32 Sony Alpha 6000 Shutter Button Replacement: passo 14, imagem 2 %32
      • Hold the top of the camera away from the body.
      • Carefully turn it over to uncover the bottom of the shutter button.
      Pergunte ao FixBot
      Comentar
    5. Sony Alpha 6000 Shutter Button Replacement: passo 15, imagem 1 %32
      • Locate the two screws holding the shutter button and unscrew them.
      Pergunte ao FixBot
      Comentar
    6. Sony Alpha 6000 Shutter Button Replacement: passo 16, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Once the screws are out, use a pair of tweezers to pull out the circular metal piece under the shutter button.
      Pergunte ao FixBot
      Comentar
    7. Sony Alpha 6000 Shutter Button Replacement: passo 17, imagem 1 %32
      • Turn the top plastic piece back over.
      • Now you will be able to completely remove the camera's shutter button.
      Pergunte ao FixBot
      Comentar
Conclusão
Now that the shutter button is removed, you will be able to replace it with a new piece. To reassemble your device, follow these instructions in reverse order.
7 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 4-5, Passmore Fall 2016 Membro de USF Tampa, Team 4-5, Passmore Fall 2016
USFT-PASSMORE-F16S4G5
3 Membros
Autoria de 40 guias
4Comentários do guia
Check also https://www.youtube.com/watch?v=y3CCJtD0...
You don't need to remove the back cover (and don't try it because first, you need to remove the top cover...)
Philippe Combronde - Responder Compartilhar
Where can i buy a replacement button?
Simon Lundh - Responder Compartilhar
You can find the flexible cable with the shutter button on aliexpress:
https://www.aliexpress.com/store/product...
Lac Uster - Responder Compartilhar
Thank you!
Arshad kltn - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 36
Últimos 30 dias: 170
Ao todo: 20,129
