Ir para o conteúdo principal
Sony Alpha 5100 LCD Replacement
O que você precisa
  1. Sony Alpha 5100 LCD Replacement, LCD: passo 1, imagem 1 %32
    • Slide the power switch on the top of the camera to "off."
  2. Sony Alpha 5100 LCD Replacement: passo 2, imagem 1 %32
    • Flip the LCD screen so that you have access to the back of the screen. The front of the screen should be facing the direction that the lens is facing.
  3. Sony Alpha 5100 LCD Replacement: passo 3, imagem 1 %32 Sony Alpha 5100 LCD Replacement: passo 3, imagem 2 %32
    • Remove the two 2mm Phillips #00 screws on the back of the screen.
    • Remove the two 2mm Phillips #00 screws on the top of the LCD screen.
  4. Sony Alpha 5100 LCD Replacement: passo 4, imagem 1 %32
    • Carefully pry open the back plate off the screen with an iFixit opening tool.
    • If separating the plates is giving you trouble, aim for the notch at the bottom of the plate.
  5. Sony Alpha 5100 LCD Replacement: passo 5, imagem 1 %32 Sony Alpha 5100 LCD Replacement: passo 5, imagem 2 %32
    • Carefully open the back plate of the screen.
Conclusão
3 outras pessoas executaram este guia.
Kevin Raggiani
Membro desde: 10/30/19
444 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S4-G6, Saloman Fall 2019 Membro de UMass Dartmouth, Team S4-G6, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G6
Membros da 3
Autoria de 8 guias
Um comentário
Hello, thank you for this but it’s only half the steps, how to remove the LCD and touch screen after step 5? Something else is holding it in place. Can lift the outer edge a little only. Possibly it is glue or tape? My touchscreen is always active and focus rectangle moving around the lower part of screen. Can touch screen and it will go there but soon moves back to lower area.
Thank you.
John Meldrum - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 57
Duração total: 1,647
