Ir para o conteúdo principal
Sony AZ1VR Lens O Ring Replacement
O que você precisa
    1. Sony AZ1VR Lens O Ring Replacement, Lens O Ring: passo 1, imagem 1 %32 Sony AZ1VR Lens O Ring Replacement, Lens O Ring: passo 1, imagem 2 %32 Sony AZ1VR Lens O Ring Replacement, Lens O Ring: passo 1, imagem 3 %32
      • Start by removing the two screws on the bottom, and the screw inside the battery room.
      • Once these are removed, slide the door out, and the small piece of plastic with the door.
      Pergunte ao FixBot
      Comentar
    2. Sony AZ1VR Lens O Ring Replacement: passo 2, imagem 1 %32 Sony AZ1VR Lens O Ring Replacement: passo 2, imagem 2 %32 Sony AZ1VR Lens O Ring Replacement: passo 2, imagem 3 %32
      • Now, grab the lens and pull the body out of the plastic, this will reveal the insides of the device.
      • You'll see a screw on the top of the device, towards the front, remove this screw.
      • Next pull the tabs on the bottom and top of the lens, and pull outward, this will remove the lens housing from the body.
      Pergunte ao FixBot
      Comentar
    3. Sony AZ1VR Lens O Ring Replacement: passo 3, imagem 1 %32
      • Next, you'll see a white ring around the lens, slowly remove that ring without causing damage to the device.
      • Now put the new one in its place. Now reassemble the device, it's all set to be used.
      Pergunte ao FixBot
      Comentar
Conclusão
Michael Martin
Membro desde: 03/08/17
401 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 505
