Ir para o conteúdo principal
Sony α6000 Lens Assembly Replacement
O que você precisa
  1. Sony α6000 Lens Assembly Replacement, Battery: passo 1, imagem 1 %32 Sony α6000 Lens Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Lens Assembly Replacement: passo 2, imagem 1 %32 Sony α6000 Lens Assembly Replacement: passo 2, imagem 2 %32
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Lens Assembly Replacement: passo 3, imagem 1 %32 Sony α6000 Lens Assembly Replacement: passo 3, imagem 2 %32
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Lens Assembly Replacement: passo 4, imagem 1 %32 Sony α6000 Lens Assembly Replacement: passo 4, imagem 2 %32
    • Extract the battery.
  5. Sony α6000 Lens Assembly Replacement, Lens Assembly: passo 5, imagem 1 %32
    • Place the camera with the lens facing upwards.
    • Remove the four 1.75 mm Phillips #00 screws from the front face of the camera.
  6. Sony α6000 Lens Assembly Replacement: passo 6, imagem 1 %32
    • Carefully remove the outer most silver ring from the lens assembly.
  7. Sony α6000 Lens Assembly Replacement: passo 7, imagem 1 %32
    • Carefully remove the black ring from the lens assembly.
  8. Sony α6000 Lens Assembly Replacement: passo 8, imagem 1 %32
    • Carefully remove the thin silver ring from the lens assembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 571
