Ir para o conteúdo principal
Sonos Playbase Subwoofer Replacement
O que você precisa
  1. Sonos Playbase Subwoofer Replacement, Bottom Panel: passo 1, imagem 1 %32 Sonos Playbase Subwoofer Replacement, Bottom Panel: passo 1, imagem 2 %32 Sonos Playbase Subwoofer Replacement, Bottom Panel: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    Pro Tech Toolkit
    $79.95
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
    Pergunte ao FixBot
    Comentar
  2. Sonos Playbase Subwoofer Replacement: passo 2, imagem 1 %32 Sonos Playbase Subwoofer Replacement: passo 2, imagem 2 %32
    Pro Tech Toolkit
    $79.95
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
    Pergunte ao FixBot
    Comentar
  3. Sonos Playbase Subwoofer Replacement: passo 3, imagem 1 %32 Sonos Playbase Subwoofer Replacement: passo 3, imagem 2 %32
    Pro Tech Toolkit
    $79.95
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
    Pergunte ao FixBot
    Comentar
  4. Sonos Playbase Subwoofer Replacement, Subwoofer: passo 4, imagem 1 %32 Sonos Playbase Subwoofer Replacement, Subwoofer: passo 4, imagem 2 %32
    Pro Tech Toolkit
    $79.95
    • Remove the three 18mm T-20 length screws by turning counter-clockwise and pulling up.
    • Remove the three 38mm T-55 length screws by turning counter-clockwise and pulling up.
    Pergunte ao FixBot
    Comentar
  5. Sonos Playbase Subwoofer Replacement: passo 5, imagem 1 %32 Sonos Playbase Subwoofer Replacement: passo 5, imagem 2 %32
    • Unclip the red and black wiring from the subwoofer by pulling them away from the subwoofer.
    Pergunte ao FixBot
    Comentar
  6. Sonos Playbase Subwoofer Replacement: passo 6, imagem 1 %32
    • Remove the subwoofer by gently lifting it up.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S17-G2, White Fall 2018 Membro de Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 40
Ao todo: 2,900
