Ir para o conteúdo principal
Sonos Playbase IR Reciver Replacement
O que você precisa
  1. Sonos Playbase IR Reciver Replacement, Bottom Panel: passo 1, imagem 1 %32 Sonos Playbase IR Reciver Replacement, Bottom Panel: passo 1, imagem 2 %32 Sonos Playbase IR Reciver Replacement, Bottom Panel: passo 1, imagem 3 %32
    Ferramenta utilizada neste passo:
    Pro Tech Toolkit
    $79.95
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
    Pergunte ao FixBot
    Comentar
  2. Sonos Playbase IR Reciver Replacement: passo 2, imagem 1 %32 Sonos Playbase IR Reciver Replacement: passo 2, imagem 2 %32
    Pro Tech Toolkit
    $79.95
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
    Pergunte ao FixBot
    Comentar
  3. Sonos Playbase IR Reciver Replacement: passo 3, imagem 1 %32 Sonos Playbase IR Reciver Replacement: passo 3, imagem 2 %32
    Pro Tech Toolkit
    $79.95
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
    Pergunte ao FixBot
    Comentar
  4. Sonos Playbase IR Reciver Replacement, Main Speaker Array: passo 4, imagem 1 %32 Sonos Playbase IR Reciver Replacement, Main Speaker Array: passo 4, imagem 2 %32
    Pergunte ao FixBot
    Comentar
  5. Sonos Playbase IR Reciver Replacement: passo 5, imagem 1 %32 Sonos Playbase IR Reciver Replacement: passo 5, imagem 2 %32
    • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
    • See Recognizing & Disconnecting Cable Connectors for more information.
    Pergunte ao FixBot
    Comentar
  6. Sonos Playbase IR Reciver Replacement: passo 6, imagem 1 %32 Sonos Playbase IR Reciver Replacement: passo 6, imagem 2 %32 Sonos Playbase IR Reciver Replacement: passo 6, imagem 3 %32
    Pro Tech Toolkit
    $79.95
    • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
    Pergunte ao FixBot
    Comentar
  7. Sonos Playbase IR Reciver Replacement: passo 7, imagem 1 %32
    • Remove the main speaker array by gripping it on both sides and pulling it out.
    • The array may require a significant amount of force to remove.
    • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
    • Do not to yank the array out too suddenly or too far as this may damage the device.
    Pergunte ao FixBot
    Comentar
  8. Sonos Playbase IR Reciver Replacement: passo 8, imagem 1 %32
    • Prop the removed main speaker array up on top of the main circuit board.
    Pergunte ao FixBot
    Comentar
  9. Sonos Playbase IR Reciver Replacement, IR Receiver: passo 9, imagem 1 %32 Sonos Playbase IR Reciver Replacement, IR Receiver: passo 9, imagem 2 %32 Sonos Playbase IR Reciver Replacement, IR Receiver: passo 9, imagem 3 %32
    Pro Tech Toolkit
    $79.95
    • Lift the main speaker array to reveal the IR receiver underneath.
    • Remove the three 11 mm T-5 screws by turning counter-clockwise.
    Pergunte ao FixBot
    Comentar
  10. Sonos Playbase IR Reciver Replacement: passo 10, imagem 1 %32 Sonos Playbase IR Reciver Replacement: passo 10, imagem 2 %32 Sonos Playbase IR Reciver Replacement: passo 10, imagem 3 %32
    Pergunte ao FixBot
    Comentar
  11. Sonos Playbase IR Reciver Replacement: passo 11, imagem 1 %32 Sonos Playbase IR Reciver Replacement: passo 11, imagem 2 %32
    • Remove the IR receiver by grasping it with two fingers and pulling up.
    Pergunte ao FixBot
    Comentar
Conclusão
George Slivka
Membro desde: 10/08/18
341 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S17-G2, White Fall 2018 Membro de Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 32
Ao todo: 1,728
