Ir para o conteúdo principal
Sonos One Power Adapter Replacement
O que você precisa
  1. Sonos One Power Adapter Replacement, Protective Cover: passo 1, imagem 1 %32 Sonos One Power Adapter Replacement, Protective Cover: passo 1, imagem 2 %32 Sonos One Power Adapter Replacement, Protective Cover: passo 1, imagem 3 %32
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
    Pergunte ao FixBot
    Comentar
  2. Sonos One Power Adapter Replacement: passo 2, imagem 1 %32 Sonos One Power Adapter Replacement: passo 2, imagem 2 %32 Sonos One Power Adapter Replacement: passo 2, imagem 3 %32
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Sonos One Power Adapter Replacement: passo 3, imagem 1 %32 Sonos One Power Adapter Replacement: passo 3, imagem 2 %32
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
    Pergunte ao FixBot
    Comentar
  4. Sonos One Power Adapter Replacement: passo 4, imagem 1 %32 Sonos One Power Adapter Replacement: passo 4, imagem 2 %32 Sonos One Power Adapter Replacement: passo 4, imagem 3 %32
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
    Pergunte ao FixBot
    Comentar
  5. Sonos One Power Adapter Replacement: passo 5, imagem 1 %32 Sonos One Power Adapter Replacement: passo 5, imagem 2 %32
    • Slide the protective cover upwards to remove.
    Pergunte ao FixBot
    Comentar
  6. Sonos One Power Adapter Replacement, Control Panel & Microphone: passo 6, imagem 1 %32 Sonos One Power Adapter Replacement, Control Panel & Microphone: passo 6, imagem 2 %32 Sonos One Power Adapter Replacement, Control Panel & Microphone: passo 6, imagem 3 %32
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
    Pergunte ao FixBot
    Comentar
  7. Sonos One Power Adapter Replacement: passo 7, imagem 1 %32 Sonos One Power Adapter Replacement: passo 7, imagem 2 %32
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
    Pergunte ao FixBot
    Comentar
  8. Sonos One Power Adapter Replacement: passo 8, imagem 1 %32 Sonos One Power Adapter Replacement: passo 8, imagem 2 %32 Sonos One Power Adapter Replacement: passo 8, imagem 3 %32
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
    Pergunte ao FixBot
    Comentar
  9. Sonos One Power Adapter Replacement: passo 9, imagem 1 %32 Sonos One Power Adapter Replacement: passo 9, imagem 2 %32
    • Pull the control panel away from the speaker to separate.
    Pergunte ao FixBot
    Comentar
  10. Sonos One Power Adapter Replacement, Power Adapter Receptacle: passo 10, imagem 1 %32 Sonos One Power Adapter Replacement, Power Adapter Receptacle: passo 10, imagem 2 %32 Sonos One Power Adapter Replacement, Power Adapter Receptacle: passo 10, imagem 3 %32
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
    Pergunte ao FixBot
    Comentar
  11. Sonos One Power Adapter Replacement: passo 11, imagem 1 %32 Sonos One Power Adapter Replacement: passo 11, imagem 2 %32
    • Using a plastic opening tool, separate the motherboard from the speaker.
    Pergunte ao FixBot
    Comentar
  12. Sonos One Power Adapter Replacement: passo 12, imagem 1 %32 Sonos One Power Adapter Replacement: passo 12, imagem 2 %32 Sonos One Power Adapter Replacement: passo 12, imagem 3 %32
    • Using your thumb, disconnect the speaker cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  13. Sonos One Power Adapter Replacement: passo 13, imagem 1 %32 Sonos One Power Adapter Replacement: passo 13, imagem 2 %32 Sonos One Power Adapter Replacement: passo 13, imagem 3 %32
    • Disconnect the power adapter plug from the motherboard using your thumb.
    Pergunte ao FixBot
    Comentar
  14. Sonos One Power Adapter Replacement: passo 14, imagem 1 %32 Sonos One Power Adapter Replacement: passo 14, imagem 2 %32 Sonos One Power Adapter Replacement: passo 14, imagem 3 %32
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
    Pergunte ao FixBot
    Comentar
  15. Sonos One Power Adapter Replacement: passo 15, imagem 1 %32 Sonos One Power Adapter Replacement: passo 15, imagem 2 %32
    • Remove the motherboard panel from the speaker housing.
    Pergunte ao FixBot
    Comentar
  16. Sonos One Power Adapter Replacement: passo 16, imagem 1 %32 Sonos One Power Adapter Replacement: passo 16, imagem 2 %32 Sonos One Power Adapter Replacement: passo 16, imagem 3 %32
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
Marcus Glowa
Membro desde: 02/14/18
1.134 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G1, Nance Spring 2018 Membro de USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 33
Últimos 30 dias: 164
Ao todo: 10,226
