Ir para o conteúdo principal
Sonos One Control Panel & Microphone Replacement
O que você precisa
  1. Sonos One Control Panel & Microphone Replacement, Protective Cover: passo 1, imagem 1 %32 Sonos One Control Panel & Microphone Replacement, Protective Cover: passo 1, imagem 2 %32 Sonos One Control Panel & Microphone Replacement, Protective Cover: passo 1, imagem 3 %32
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
    Pergunte ao FixBot
    Comentar
  2. Sonos One Control Panel & Microphone Replacement: passo 2, imagem 1 %32 Sonos One Control Panel & Microphone Replacement: passo 2, imagem 2 %32 Sonos One Control Panel & Microphone Replacement: passo 2, imagem 3 %32
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Sonos One Control Panel & Microphone Replacement: passo 3, imagem 1 %32 Sonos One Control Panel & Microphone Replacement: passo 3, imagem 2 %32
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
    Pergunte ao FixBot
    Comentar
  4. Sonos One Control Panel & Microphone Replacement: passo 4, imagem 1 %32 Sonos One Control Panel & Microphone Replacement: passo 4, imagem 2 %32 Sonos One Control Panel & Microphone Replacement: passo 4, imagem 3 %32
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
    Pergunte ao FixBot
    Comentar
  5. Sonos One Control Panel & Microphone Replacement: passo 5, imagem 1 %32 Sonos One Control Panel & Microphone Replacement: passo 5, imagem 2 %32
    • Slide the protective cover upwards to remove.
    Pergunte ao FixBot
    Comentar
  6. Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: passo 6, imagem 1 %32 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: passo 6, imagem 2 %32 Sonos One Control Panel & Microphone Replacement, Control Panel & Microphone: passo 6, imagem 3 %32
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
    Pergunte ao FixBot
    Comentar
  7. Sonos One Control Panel & Microphone Replacement: passo 7, imagem 1 %32 Sonos One Control Panel & Microphone Replacement: passo 7, imagem 2 %32
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
    Pergunte ao FixBot
    Comentar
  8. Sonos One Control Panel & Microphone Replacement: passo 8, imagem 1 %32 Sonos One Control Panel & Microphone Replacement: passo 8, imagem 2 %32 Sonos One Control Panel & Microphone Replacement: passo 8, imagem 3 %32
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
    Pergunte ao FixBot
    Comentar
  9. Sonos One Control Panel & Microphone Replacement: passo 9, imagem 1 %32 Sonos One Control Panel & Microphone Replacement: passo 9, imagem 2 %32
    • Pull the control panel away from the speaker to separate.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Marcus Glowa
Membro desde: 02/14/18
1.134 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S2-G1, Nance Spring 2018 Membro de USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 Membros
Autoria de 14 guias
1Comentário do guia
where can I buy a replacement control panel?
Chris Myers - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 98
Ao todo: 8,480
