Ir para o conteúdo principal
Sonos Five Midwoofer Replacement
  1. Sonos Five Midwoofer Replacement, Grille Removal: passo 1, imagem 1 %32 Sonos Five Midwoofer Replacement, Grille Removal: passo 1, imagem 2 %32 Sonos Five Midwoofer Replacement, Grille Removal: passo 1, imagem 3 %32
    • Use a thin guitar pick to carefully pry up the grille (photo one)
    • Ensure you position the pick to pry between the side of the case and the rubber grille frame; not the plastic mesh! (photos two and three)
    Pergunte ao FixBot
    Comentar
  2. Sonos Five Midwoofer Replacement, Grill Removal Continued: passo 2, imagem 1 %32 Sonos Five Midwoofer Replacement, Grill Removal Continued: passo 2, imagem 2 %32 Sonos Five Midwoofer Replacement, Grill Removal Continued: passo 2, imagem 3 %32
    • Continue to work your way around the sides until the grille is freed.
    • Make note of the red circled posts and their respective matching pins. They must be properly aligned when reinstalling the grille to prevent damage.
    Pergunte ao FixBot
    Comentar
  3. Sonos Five Midwoofer Replacement, Left Midwoofer Removal: passo 3, imagem 1 %32 Sonos Five Midwoofer Replacement, Left Midwoofer Removal: passo 3, imagem 2 %32 Sonos Five Midwoofer Replacement, Left Midwoofer Removal: passo 3, imagem 3 %32
    • Remove the four red circled Torx T20 screws securing the driver to the front panel.
    • Be sure to align the speaker properly with it's alignment posts during reinstallation (third photo, red arrow)
    Pergunte ao FixBot
    Comentar
  4. Sonos Five Midwoofer Replacement, Disconnecting The Driver: passo 4, imagem 1 %32 Sonos Five Midwoofer Replacement, Disconnecting The Driver: passo 4, imagem 2 %32 Sonos Five Midwoofer Replacement, Disconnecting The Driver: passo 4, imagem 3 %32
    • The insulated terminal simply pulls off to disconnect.
    • The non insulated terminal has a locking tab (red arrow, second photo). This tab that must be depressed with a small screwdriver to unlock it for removal.
    • The midwoofer may now be carefully removed from the supporting frame.
    Pergunte ao FixBot
    Comentar
  5. Sonos Five Midwoofer Replacement, Center Midwoofer removal: passo 5, imagem 1 %32 Sonos Five Midwoofer Replacement, Center Midwoofer removal: passo 5, imagem 2 %32 Sonos Five Midwoofer Replacement, Center Midwoofer removal: passo 5, imagem 3 %32
    • Raise the midwoofer out of the cabinet slightly to enable you to disconnect the terminals.
    • The center midwoofer driver wires are extremely short. Be Careful not to place too much tension on the wires. This takes two hands one holding the driver while you disconnect the terminals with the other.
    • Again, the insulated terminal simply slides off, but the non insulated terminal's locking tab must be depressed.
    Pergunte ao FixBot
    Comentar
  6. Sonos Five Midwoofer Replacement, Right Midwoofer Removal: passo 6, imagem 1 %32 Sonos Five Midwoofer Replacement, Right Midwoofer Removal: passo 6, imagem 2 %32 Sonos Five Midwoofer Replacement, Right Midwoofer Removal: passo 6, imagem 3 %32
    • Remove the four T20 screws securing the driver to the front panel
    • Lift the driver out of the cabinet.
    • The left noninsulated terminal again has a locking tab that must be depressed. (red arrow, photo two) The right terminal is simply pulled off.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Nicholas Ouimet
Membro desde: 10/16/09
3.700 Reputação
Autoria de 11 guias
2Comentários do guia
Hola sabes donde podría comprar los parlantes tengo un somos five y están las tres bocinas reventadas
Ricardo.tranamil.h@gmail.com
Ricardo tranamil - Responder Compartilhar
Hola nesecito comprar las bocinas de repuestos por favor
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 73
Ao todo: 3,487
