Introdução
If your Solio Xcellerator and Hub Battery Pack Solar Panel will not charge even after connecting all the necessary cables and placing it in direct sunlight, then you may have an issue with the battery within the Charger Hub. This issue could potentially be a corroding battery, so when inspecting make note of the batteries appearance. Corrosion can be identified by a crusty material on/nearby the battery. If this is the case, a replacement of the battery is the best option.
This guide covers how to disassemble the solar panel portion of the Solio Xcellerator and Hub Battery Pack Solar Panel. It covers both a complete removal, and a replacement of the solar panel in a step-by-step instruction. If the solar panel portion is not working, following this guide will ensure you are able to fix the problem.
To avoid any damages, make sure the Solio Xcellerator and Hub Battery Pack Solar Panel is not connected to anything before beginning.
O que você precisa
Ferramenta utilizada neste passo:iFixit Opening Picks (Set of 6)$4.99
Keep on sliding iFixit Opening Picks into the edges of the panel without removing the ones already in place. The panel may reattach if the clips are not completely broken.
Ferramenta utilizada neste passo:Flush Cutter$29.99
Place the solar panel on a surface that you can solder on.
Cut the two wires connecting the circuit board to the solar panel at the base near the solar panel by using wire cutters.
Take out the Soldering Station. With the new solar panel, solder each lead back to the circuit board, ensuring the positive and negative leads match up correctly as displayed in the photo. Refer to the Repairing Soldered Connection Guide.
Put the device back together following the same guide in reverse order.
When you reach step 8, apply your Evo-Stick Super Glue along the edges of the plastic panel.
Press the panel back into place on the device. Let it sit and dry for 24 hours before use.
Enjoy your working device!
For reassembly of the device, please follow the instructions in the reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 outras pessoas executaram este guia.
