Introdução
The 3.7V/3, 200mAh Li-Poly battery is a key component because it stores the power within the device. If it burns out, it must be replaced.
O que você precisa
Turn off the device by pressing on the clear power button behind the device.
Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
