Ir para o conteúdo principal
Sol Republic Deck LED Lights Replacement
O que você precisa
  1. Sol Republic Deck LED Lights Replacement, LED Lights: passo 1, imagem 1 %32 Sol Republic Deck LED Lights Replacement, LED Lights: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Spudger
    $3.99
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Insert the tip of a plastic opening tool or Spudger into the the middle groove along the edge of the device.
    • Insert another opening tool into the groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
    Pergunte ao FixBot
    Comentar
  2. Sol Republic Deck LED Lights Replacement: passo 2, imagem 1 %32 Sol Republic Deck LED Lights Replacement: passo 2, imagem 2 %32
    Phillips #00 Screwdriver
    $5.49
    • Using a Phillips #00 Screwdriver, unscrew the two three-tenth cm screws and remove them.
    • Once the screws have been removed, lift the SOL plate revealing the LED Light strip.
    Pergunte ao FixBot
    Comentar
  3. Sol Republic Deck LED Lights Replacement: passo 3, imagem 1 %32
    $5.49
    Pergunte ao FixBot
    Comentar
  4. Sol Republic Deck LED Lights Replacement: passo 4, imagem 1 %32
    $5.49
    Pergunte ao FixBot
    Comentar
  5. Sol Republic Deck LED Lights Replacement: passo 5, imagem 1 %32
    • Use fingers to gently lift tab to help remove ZIF connector.
    • Use tweezers and to gently lift ZIF (Zero Insertion Force) connector.
    Pergunte ao FixBot
    Comentar
  6. Sol Republic Deck LED Lights Replacement: passo 6, imagem 1 %32
    • Once unscrewed, the LED light requiring repair can be accessed by lifting up the entire LED light strip with tweezers.
    Pergunte ao FixBot
    Comentar
  7. Sol Republic Deck LED Lights Replacement: passo 7, imagem 1 %32
    • Lift the LED light plate attached to the motherboard off.
    • If you pull the LED light plate too hard, then the motherboard will snap in half.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 2,426
