Ir para o conteúdo principal
SodaStream Source Microchip Replacement
O que você precisa
  1. SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: passo 1, imagem 1 %32 SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: passo 1, imagem 2 %32 SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: passo 1, imagem 3 %32
    • Remove the soda bottle and the CO₂ canister from the machine.
    Pergunte ao FixBot
    Comentar
  2. SodaStream Source Microchip Replacement: passo 2, imagem 1 %32 SodaStream Source Microchip Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    Phillips #1 Screwdriver
    $8.99
    Pergunte ao FixBot
    Comentar
  3. SodaStream Source Microchip Replacement: passo 3, imagem 1 %32 SodaStream Source Microchip Replacement: passo 3, imagem 2 %32
    • Pull the outer cover away from the front of the device.
    Pergunte ao FixBot
    Comentar
  4. SodaStream Source Microchip Replacement: passo 4, imagem 1 %32
    $8.99
    Pergunte ao FixBot
    Comentar
  5. SodaStream Source Microchip Replacement: passo 5, imagem 1 %32 SodaStream Source Microchip Replacement: passo 5, imagem 2 %32
    Jimmy
    $7.95
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
    Pergunte ao FixBot
    Comentar
  6. SodaStream Source Microchip Replacement, Microchip: passo 6, imagem 1 %32
    • Remove the 9.1 mm screw from the microchip.
    Pergunte ao FixBot
    Comentar
  7. SodaStream Source Microchip Replacement: passo 7, imagem 1 %32 SodaStream Source Microchip Replacement: passo 7, imagem 2 %32 SodaStream Source Microchip Replacement: passo 7, imagem 3 %32
    • Wedge the plastic spudger between the microchip and the glue dot until the glue pops off.
    Pergunte ao FixBot
    Comentar
  8. SodaStream Source Microchip Replacement: passo 8, imagem 1 %32 SodaStream Source Microchip Replacement: passo 8, imagem 2 %32 SodaStream Source Microchip Replacement: passo 8, imagem 3 %32
    Spudger
    $2.99
    • Use the spudger to lift the edge of the wire and pull the wire out of the microchip.
    • Use an ESD tool such as a nylon spudger when working with potentially dangerous electronics.
    • While reconnecting the wires, you will need a hot glue gun to reattach the wire ends to the new chip.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S1-G4, Leahy Spring 2017 Membro de USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Membros
Autoria de 48 guias
4Comentários do guia
Great information, but is there someone out there offering this repair as a service, I’m not motivated enough to do this myself and happy to pay someone to do it for me
matteo barnett - Responder Compartilhar
Where can you buy the microchip please?
Jill - Responder Compartilhar
Where can you purchase a replacement microchip from?
David Grosz - Responder Compartilhar
Where can I find the reassemble source at
mcphersonp411 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 115
Ao todo: 6,055
