Ir para o conteúdo principal
SodaStream Source Loader Tab Replacement
O que você precisa
  1. SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: passo 1, imagem 1 %32 SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: passo 1, imagem 2 %32 SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: passo 1, imagem 3 %32
    • Remove the soda bottle and the CO₂ canister from the machine.
    Pergunte ao FixBot
    Comentar
  2. SodaStream Source Loader Tab Replacement: passo 2, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    Phillips #1 Screwdriver
    $8.99
    Pergunte ao FixBot
    Comentar
  3. SodaStream Source Loader Tab Replacement: passo 3, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 3, imagem 2 %32
    • Pull the outer cover away from the front of the device.
    Pergunte ao FixBot
    Comentar
  4. SodaStream Source Loader Tab Replacement: passo 4, imagem 1 %32
    $8.99
    Pergunte ao FixBot
    Comentar
  5. SodaStream Source Loader Tab Replacement: passo 5, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 5, imagem 2 %32
    Jimmy
    $7.95
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
    Pergunte ao FixBot
    Comentar
  6. SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: passo 6, imagem 1 %32 SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: passo 6, imagem 2 %32 SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: passo 6, imagem 3 %32
    • Push the brass bar, located in the top of the device, out of the carbonating block.
    • You can use the end of your screwdriver to push this piece out.
    Pergunte ao FixBot
    Comentar
  7. SodaStream Source Loader Tab Replacement: passo 7, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 7, imagem 2 %32 SodaStream Source Loader Tab Replacement: passo 7, imagem 3 %32
    • Slide the yellow battery cover up and away to remove it from the device.
    Pergunte ao FixBot
    Comentar
  8. SodaStream Source Loader Tab Replacement: passo 8, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 8, imagem 2 %32
    • Unhook the bottom piece of the plastic arm on each side of the device.
    Pergunte ao FixBot
    Comentar
  9. SodaStream Source Loader Tab Replacement: passo 9, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 9, imagem 2 %32
    • Lift the top of the plastic arm with the spudger and remove it on both sides.
    Pergunte ao FixBot
    Comentar
  10. SodaStream Source Loader Tab Replacement: passo 10, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 10, imagem 2 %32
    • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
    Pergunte ao FixBot
    Comentar
  11. SodaStream Source Loader Tab Replacement: passo 11, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 11, imagem 2 %32
    • Remove the plastic oval and the spring within it.
    Pergunte ao FixBot
    Comentar
  12. SodaStream Source Loader Tab Replacement: passo 12, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 12, imagem 2 %32
    • Pull the loader tab cover down and away from the rest of the carbonating block.
    Pergunte ao FixBot
    Comentar
  13. SodaStream Source Loader Tab Replacement: passo 13, imagem 1 %32
    • Remove the three 17.9 mm screws located on the right side.
    • These screws may be difficult to access.
    Pergunte ao FixBot
    Comentar
  14. SodaStream Source Loader Tab Replacement: passo 14, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 14, imagem 2 %32
    • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
    Pergunte ao FixBot
    Comentar
  15. SodaStream Source Loader Tab Replacement: passo 15, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 15, imagem 2 %32 SodaStream Source Loader Tab Replacement: passo 15, imagem 3 %32
    • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
    Pergunte ao FixBot
    Comentar
  16. SodaStream Source Loader Tab Replacement: passo 16, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 16, imagem 2 %32
    • Unhook the silver spring arms on both sides of the device by pushing down.
    Pergunte ao FixBot
    Comentar
  17. SodaStream Source Loader Tab Replacement: passo 17, imagem 1 %32
    • Grip the right and left sides of the device and pull it into two identical halves.
    • Once these two pieces are apart, all remaining internal components will fall out of the device.
    Pergunte ao FixBot
    Comentar
  18. SodaStream Source Loader Tab Replacement: passo 18, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 18, imagem 2 %32 SodaStream Source Loader Tab Replacement: passo 18, imagem 3 %32
    • Pull the foam pad up and remove it from the front side of the carbonation component.
    Pergunte ao FixBot
    Comentar
  19. SodaStream Source Loader Tab Replacement: passo 19, imagem 1 %32
    • Remove the six 17.7 mm screws from the underside of the loader tab piece.
    Pergunte ao FixBot
    Comentar
  20. SodaStream Source Loader Tab Replacement: passo 20, imagem 1 %32 SodaStream Source Loader Tab Replacement: passo 20, imagem 2 %32 SodaStream Source Loader Tab Replacement: passo 20, imagem 3 %32
    • Pull the loader tab out of the nozzle.
    Pergunte ao FixBot
    Comentar
  21. SodaStream Source Loader Tab Replacement, Loader Tab: passo 21, imagem 1 %32 SodaStream Source Loader Tab Replacement, Loader Tab: passo 21, imagem 2 %32 SodaStream Source Loader Tab Replacement, Loader Tab: passo 21, imagem 3 %32
    • Pull the small inner plastic circle out of the large plastic loader tab piece.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S1-G4, Leahy Spring 2017 Membro de USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Membros
Autoria de 41 guias
6Comentários do guia
Thank you SO much for this! I was having a lot of trouble with this thing not releasing the bottle, so I disassembled it all and put it back together and now it works a treat! Not sure what was going on but I am so excited. You weren’t kidding at the end about it all falling apart… took ages to work out how it all went back together, but now I understand it and I have a working SodaStream. 5*!
Amanda L - Responder Compartilhar
Do you know where the tiny magnet goes? It fell out on the table as I was disassembling.
cheryl meeks - Responder Compartilhar
I think it has something to do with the microchip for the LED’s. Can’t figure out how else the light would light. I haven’t taken it apart far enough to find the magnet. Hope this helps you.
Paul Bibeau - Responder Compartilhar
You can see the magnet in step 18, the first picture. Its right below where a screw used to be.
Tom Green - Responder Compartilhar
I placed sodastream on side and removed top half. I could then see where parts needed to be after they “fell out” for reassembly. More pictures of those steps would be helpful. Thank
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 62
Últimos 30 dias: 231
Ao todo: 29,000
