Ir para o conteúdo principal
SodaStream Source Battery Replacement
O que você precisa
    1. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: passo 1, imagem 1 %32 SodaStream Source Battery Replacement, SodaStream Source External Disassembly: passo 1, imagem 2 %32 SodaStream Source Battery Replacement, SodaStream Source External Disassembly: passo 1, imagem 3 %32
      • Remove the soda bottle and the CO₂ canister from the machine.
      Pergunte ao FixBot
      Comentar
    2. SodaStream Source Battery Replacement: passo 2, imagem 1 %32 SodaStream Source Battery Replacement: passo 2, imagem 2 %32
      Ferramenta utilizada neste passo:
      Phillips #1 Screwdriver
      $8.99
      Pergunte ao FixBot
      Comentar
    3. SodaStream Source Battery Replacement: passo 3, imagem 1 %32 SodaStream Source Battery Replacement: passo 3, imagem 2 %32
      • Pull the outer cover away from the front of the device.
      Pergunte ao FixBot
      Comentar
    4. SodaStream Source Battery Replacement: passo 4, imagem 1 %32
      $8.99
      Pergunte ao FixBot
      Comentar
    5. SodaStream Source Battery Replacement: passo 5, imagem 1 %32 SodaStream Source Battery Replacement: passo 5, imagem 2 %32
      Jimmy
      $7.95
      • Firmly pull the front cover off.
      • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
      Pergunte ao FixBot
      Comentar
    1. SodaStream Source Battery Replacement, Battery: passo 6, imagem 1 %32 SodaStream Source Battery Replacement, Battery: passo 6, imagem 2 %32
      • Remove the old battery and replace it with a new 3V lithium battery.
      Pergunte ao FixBot
      Comentar
Conclusão
30 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S1-G4, Leahy Spring 2017 Membro de USF Tampa, Team S1-G4, Leahy Spring 2017
USFT-LEAHY-S17S1G4
3 Membros
Autoria de 48 guias
22Comentários do guia
Heel de achterkant hoeft er hiervoor niet af hoor juist de voorkant 2 vijsjes en je kan het voorste deksel er af klikken ;)
tomclaes1989 - Responder Compartilhar
Perfectly explained! I was afraid to pull the front cover because it does indeed take a lot of force to pull off!!
its important to note it’s a C123A 3v battery, not the C2 3v as I found out after opening
Kevin Shiner - Responder Compartilhar
Where is the best place to find these batteries? Canadian tire?
Dancingdaisy007 S - Responder Compartilhar
Its the same battery many many products use usually built in , motherboards used it for years.
Kal Jak - Responder Compartilhar
Staples has the 123A 3v battery
scottvelasco - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 32
Últimos 7 dias: 222
Últimos 30 dias: 969
Ao todo: 116,800
