Ir para o conteúdo principal
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: passo 1, imagem 1 %32 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: passo 1, imagem 2 %32
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
    Pergunte ao FixBot
    Comentar
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: passo 2, imagem 1 %32 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: passo 2, imagem 2 %32
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
    Pergunte ao FixBot
    Comentar
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: passo 3, imagem 1 %32 SodaStream Fountain Jet A200 Spring Replacement, spring removal: passo 3, imagem 2 %32
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
2Comentários do guia
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Responder Compartilhar
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 36
Últimos 30 dias: 131
Ao todo: 11,682
