Ir para o conteúdo principal
Snowboard Traction Pad Replacement
O que você precisa
    1. Snowboard Traction Pad Replacement, Traction Pad: passo 1, imagem 1 %32 Snowboard Traction Pad Replacement, Traction Pad: passo 1, imagem 2 %32
      • Use a plastic or metal scraper to remove the existing traction pad.
      Pergunte ao FixBot
      Comentar
    2. Snowboard Traction Pad Replacement: passo 2, imagem 1 %32 Snowboard Traction Pad Replacement: passo 2, imagem 2 %32 Snowboard Traction Pad Replacement: passo 2, imagem 3 %32
      • If there is any residual adhesive left from the old traction pad, soak it with adhesive remover.
      • Let the adhesive remover sit for a few minutes.
      • Wipe away the residue using a towel and water.
      • Dry the the surface where the new traction pad will be placed.
      Pergunte ao FixBot
      Comentar
    3. Snowboard Traction Pad Replacement: passo 3, imagem 1 %32 Snowboard Traction Pad Replacement: passo 3, imagem 2 %32 Snowboard Traction Pad Replacement: passo 3, imagem 3 %32
      • Peel the back off of the new traction pad to reveal the adhesive.
      • When placed, the traction pad should be about an inch away from the rear binding.
      • To avoid creating air bubbles, start with one corner of the pad and roll the rest down.
      • Press down firmly to help it stick to the board and remove any air bubbles that may have occurred.
      • Give the adhesive a minimum of 12 hours to dry before use.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
Jacob Garcia
Membro desde: 01/13/14
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-4, Forte Winter 2014 Membro de Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 3,987
