Ir para o conteúdo principal
Snowboard Binding Replacement
O que você precisa
    1. Snowboard Binding Replacement, Binding: passo 1, imagem 1 %32
      • Start by having the new snowboard binding and screws set aside. Make sure to also have a standard Phillips screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Snowboard Binding Replacement: passo 2, imagem 1 %32
      • First, align the screw and attach the plastic strip.
      Pergunte ao FixBot
      Comentar
    3. Snowboard Binding Replacement: passo 3, imagem 1 %32
      • Then begin to tighten the plastic strip by using the screwdriver with one hand and then holding the nut with the other to tighten the plastic strip.
      Pergunte ao FixBot
      Comentar
    4. Snowboard Binding Replacement: passo 4, imagem 1 %32
      • This is what it should look like so far.
      Pergunte ao FixBot
      Comentar
    5. Snowboard Binding Replacement: passo 5, imagem 1 %32
      • Now we will begin to attach the strap to the opposite side. Like previously, you will need a screwdriver to tighten the strap once you have aligned the screw and attached the nut on the other side.
      Pergunte ao FixBot
      Comentar
    6. Snowboard Binding Replacement: passo 6, imagem 1 %32
      • Make sure to not tighten it too much as the strap needs to be able to move slightly.
      Pergunte ao FixBot
      Comentar
    7. Snowboard Binding Replacement: passo 7, imagem 1 %32
      • Once everything is tightened properly this is what it should look like. Congrats you have successfully repaired a snowboard binding!!!
      Pergunte ao FixBot
      Comentar
      • Now it's time to take a picture with your fix!
      Pergunte ao FixBot
      Comentar
Conclusão
Justin
Membro desde: 04/13/22
157 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 434
