Ir para o conteúdo principal
Snapfon ez One Motherboard Replacement
O que você precisa
  1. Snapfon ez One Motherboard Replacement, Remove the battery cover: passo 1, imagem 1 %32
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
    Pergunte ao FixBot
    Comentar
  2. Snapfon ez One Motherboard Replacement, Remove the battery: passo 2, imagem 1 %32
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
    Pergunte ao FixBot
    Comentar
  3. Snapfon ez One Motherboard Replacement, Removing the plastic inserts: passo 3, imagem 1 %32 Snapfon ez One Motherboard Replacement, Removing the plastic inserts: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
    Pergunte ao FixBot
    Comentar
  4. Snapfon ez One Motherboard Replacement, Remove the shield screws: passo 4, imagem 1 %32 Snapfon ez One Motherboard Replacement, Remove the shield screws: passo 4, imagem 2 %32 Snapfon ez One Motherboard Replacement, Remove the shield screws: passo 4, imagem 3 %32
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Snapfon ez One Motherboard Replacement, Separate the case: passo 5, imagem 1 %32 Snapfon ez One Motherboard Replacement, Separate the case: passo 5, imagem 2 %32 Snapfon ez One Motherboard Replacement, Separate the case: passo 5, imagem 3 %32
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
    Pergunte ao FixBot
    Comentar
  6. Snapfon ez One Motherboard Replacement, Remove the volume slider: passo 6, imagem 1 %32
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
    Pergunte ao FixBot
    Comentar
  7. Snapfon ez One Motherboard Replacement, Remove the motherboard: passo 7, imagem 1 %32 Snapfon ez One Motherboard Replacement, Remove the motherboard: passo 7, imagem 2 %32 Snapfon ez One Motherboard Replacement, Remove the motherboard: passo 7, imagem 3 %32
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
    Pergunte ao FixBot
    Comentar
Conclusão
John Bender
Membro desde: 03/26/14
818 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 6-5, Benson Spring 2014 Membro de Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 506
