Ir para o conteúdo principal
Slingbox SOLO DC Power Connector Replacement
O que você precisa
  1. Slingbox SOLO DC Power Connector Replacement, Motherboard: passo 1, imagem 1 %32
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. Slingbox SOLO DC Power Connector Replacement: passo 2, imagem 1 %32 Slingbox SOLO DC Power Connector Replacement: passo 2, imagem 2 %32 Slingbox SOLO DC Power Connector Replacement: passo 2, imagem 3 %32
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. Slingbox SOLO DC Power Connector Replacement: passo 3, imagem 1 %32 Slingbox SOLO DC Power Connector Replacement: passo 3, imagem 2 %32 Slingbox SOLO DC Power Connector Replacement: passo 3, imagem 3 %32
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
  4. Slingbox SOLO DC Power Connector Replacement, DC Power Connector: passo 4, imagem 1 %32
    • Do not touch the heated tip of the soldering iron.
    • Check this guide out to learn how to use a soldering iron.
    • Desolder all three lead prongs.
    • Gently pull the DC power connector from the motherboard.
Conclusão
To reassemble your device, follow the instructions in reverse order.
Nitin Muralidhar
Membro desde: 07/18/16
222 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-2, Harley SU 2016 Membro de IUPUI, Team 2-2, Harley SU 2016
IUPUI-HARLEY-SU16S2G2
Membros da 5
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 290
