Ir para o conteúdo principal
Skytex Skypad Alpha 2 Battery Replacement
O que você precisa
  1. Skytex Skypad Alpha 2 Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Battery Replacement: passo 2, imagem 1 %32 Skytex Skypad Alpha 2 Battery Replacement: passo 2, imagem 2 %32
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Battery Replacement: passo 3, imagem 1 %32
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Battery Replacement: passo 4, imagem 1 %32
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Remove soldered connections to separate the battery wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on motherboard.
    • Following the red and black wires, that come out of the battery, to their respective connections on the motherboard will indicate where to solder.
    • Follow link for further soldering information: How to Solder and Desolder Connections
  6. Skytex Skypad Alpha 2 Battery Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to remove battery from tablet.
    • Be sure to remove the battery carefully to avoid damage. Damage of battery can release harmful chemicals and may cause a fire.
Conclusão
Uma outra pessoa concluiu este guia.
Rebecca Ramirez
Membro desde: 09/23/15
481 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 6-5, Williams Fall 2015 Membro de Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
Membros da 3
Autoria de 8 guias
Um comentário
Excellent Guide
Problem is where to obtain the Replacement battery ???
J P SULLIVAN - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 791
