Ir para o conteúdo principal
Skytex SP728 Screen Replacement
O que você precisa
    1. Skytex SP728 Screen Replacement, Case: passo 1, imagem 1 %32
      • Make sure the device is powered off
      • Rotate the device so the ports and screws face you
      Pergunte ao FixBot
      Comentar
    2. Skytex SP728 Screen Replacement: passo 2, imagem 1 %32
      • Using a small phillips screwdriver, unscrew both end screws
      Pergunte ao FixBot
      Comentar
    3. Skytex SP728 Screen Replacement: passo 3, imagem 1 %32
      • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
      Pergunte ao FixBot
      Comentar
    4. Skytex SP728 Screen Replacement: passo 4, imagem 1 %32
      • Once the case has been loosened, pry the backing off gently with your hands.
      • Make sure to remove the case gently as extra force can break the clasps or the case itself.
      Pergunte ao FixBot
      Comentar
    1. Skytex SP728 Screen Replacement, Screen: passo 5, imagem 1 %32 Skytex SP728 Screen Replacement, Screen: passo 5, imagem 2 %32 Skytex SP728 Screen Replacement, Screen: passo 5, imagem 3 %32
      • Follow the Case Replacement to separate the tablet from its backing
      • Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
      • Remove all tape connecting battery and circuit board to front case
      • Detach all connector strips from the circuit board
      Pergunte ao FixBot
      Comentar
    2. Skytex SP728 Screen Replacement: passo 6, imagem 1 %32 Skytex SP728 Screen Replacement: passo 6, imagem 2 %32
      • Using the plastic opening tool, begin separating the front screen from the display
      Pergunte ao FixBot
      Comentar
    3. Skytex SP728 Screen Replacement: passo 7, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Once screen has been separated, use tweezers to remove front camera
      Pergunte ao FixBot
      Comentar
Conclusão
To reassemble your device with a new screen, follow these instructions in reverse order.
Equipe
USF Tampa, Team 5-1, Brown Winter 2015 Membro de USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 450
