Ir para o conteúdo principal
Skullcandy UPROCK Earpiece Wiring Replacement
O que você precisa
  1. Skullcandy UPROCK Earpiece Wiring Replacement, Earpiece Wiring: passo 1, imagem 1 %32
    • Remove the cushion from the ear piece.
  2. Skullcandy UPROCK Earpiece Wiring Replacement: passo 2, imagem 1 %32 Skullcandy UPROCK Earpiece Wiring Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 to unscrew three 3.4MM screws from the earpiece.
  3. Skullcandy UPROCK Earpiece Wiring Replacement: passo 3, imagem 1 %32 Skullcandy UPROCK Earpiece Wiring Replacement: passo 3, imagem 2 %32
    • Find the wires connected to the speaker and check if they are intact.
  4. Skullcandy UPROCK Earpiece Wiring Replacement: passo 4, imagem 1 %32
    • If a wire is broken, use a soldering iron to reattach it to the speaker.
    • To learn how to solder, read the Como soldar e dessoldar contatos Guide.
    • After soldering is complete, the wires should look like this.
Linha de Chegada
Um comentário
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
Anuj Verma - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 6,256
