Ir para o conteúdo principal
SkullCandy INK'D 2 Audio Jack Replacement
O que você precisa
  1. SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: passo 1, imagem 1 %32 SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: passo 1, imagem 2 %32
    • Use wire cutters to remove the audio jack.
    • Use wire cutters to remove approximately 1/2 inch of insulation of the wire and separate the four wires inside of it.
    • Red wire is the right speaker '+' terminal.
    • Green wire is the left speaker '+' terminal.
    • Golden wire is the ground terminal.
    • Purple wire is the microphone terminal.
  2. SkullCandy INK'D 2 Audio Jack Replacement: passo 2, imagem 1 %32
    • Take the replacement connector and separate the wires on it.
    • Red wire is the right earphone.
    • Green wire is the left earphone.
    • Blue wire is the ground terminal.
    • Gold wire is the microphone.
  3. SkullCandy INK'D 2 Audio Jack Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Heat Shrink Tubing Assortment
    $7.99
    Comprar
    • Put shrink tubing on either one of the wires.
    • For each wire color, put the headphone wire and the replacement wire into clamps. Weave them together using fingers.
    • Review the soldering guide before initiating Step 4.
  4. SkullCandy INK'D 2 Audio Jack Replacement: passo 4, imagem 1 %32
    • Use soldering equipment to solder together two wires.
    • Repeat this step for each of the four wire colors.
    • Always wear safety glasses when soldering.
  5. SkullCandy INK'D 2 Audio Jack Replacement: passo 5, imagem 1 %32
    Digital Multimeter
    $19.99
    Comprar
    • Using Digital Multimeter in the "Continuity" mode, place two probes on the soldered wires of the same color. You will hear audio signal indicating that there is a connection.
    • Repeat this for each of the wire colors.
    • If there is no Multimeter signal, you will need to resolder the wires and to make sure that wires of different colors are completely separated.
  6. SkullCandy INK'D 2 Audio Jack Replacement: passo 6, imagem 1 %32 SkullCandy INK'D 2 Audio Jack Replacement: passo 6, imagem 2 %32 SkullCandy INK'D 2 Audio Jack Replacement: passo 6, imagem 3 %32
    Heat Gun
    $24.99
    Comprar
    • After all wires are soldered, cover them with shrink tubing.
    • Use the heat gun to shrink the tubing and fit it tightly around the wires.
    • Gently apply heat in order to shape the tubing around the soldered wires.
Conclusão
Repeat the procedure if you need to install a new audio jack.
Maksim Bondaruk
Membro desde: 10/16/17
119 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S4-G1, Livingston Fall 2017 Membro de Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
Membros da 5
Autoria de 25 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 31
Últimos 30 dias: 129
Duração total: 15,597
