Ir para o conteúdo principal
Skil 88 Motor Replacement
O que você precisa
    1. Skil 88 Motor Replacement, Disassembling Skil 88 Front Housing: passo 1, imagem 1 %32
      • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
      Pergunte ao FixBot
      Comentar
    2. Skil 88 Motor Replacement: passo 2, imagem 1 %32 Skil 88 Motor Replacement: passo 2, imagem 2 %32
      • Pull the front housing apart from the rear.
      • The motor and gears might fall out when you are pulling it apart.
      Pergunte ao FixBot
      Comentar
    1. Skil 88 Motor Replacement, Motor: passo 3, imagem 1 %32 Skil 88 Motor Replacement, Motor: passo 3, imagem 2 %32
      • Remove the gear that is threaded onto the divider.
      Pergunte ao FixBot
      Comentar
    2. Skil 88 Motor Replacement: passo 4, imagem 1 %32 Skil 88 Motor Replacement: passo 4, imagem 2 %32
      • Remove the divider from the rear housing.
      • The motor may come out along with the divider.
      Pergunte ao FixBot
      Comentar
    3. Skil 88 Motor Replacement: passo 5, imagem 1 %32 Skil 88 Motor Replacement: passo 5, imagem 2 %32
      • Pull out the motor.
      Pergunte ao FixBot
      Comentar
    4. Skil 88 Motor Replacement: passo 6, imagem 1 %32 Skil 88 Motor Replacement: passo 6, imagem 2 %32 Skil 88 Motor Replacement: passo 6, imagem 3 %32
      Ferramenta utilizada neste passo:
      • For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
      • Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
      • Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
      Pergunte ao FixBot
      Comentar
Conclusão
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
Membro desde: 10/10/10
365 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 5-17, Maness Fall 2010 Membro de Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 36
Ao todo: 1,095
