Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the lock clockwise until two screws are visible.
Remove both screws from the lock cylinder using a Phillips #3 screwdriver.
Remove the pin and key cylinder from both of the secondary and primary support cylinders.
Remove the secondary support cylinder from the primary support cylinder.
Remove both of the 3/4 inch screws from the face of the latch mechanism using a Phillips #3 screwdriver.
Remove the latch mechanism with the latch face from the door.
Insert the new latch mechanism with the latch face in the door. A capital letter "A" should face upward in the latch face.
Reinsert both of the screws in the latch face using a Phillips #3 screwdriver.
Insert the new pin and key cylinder in both the primary and secondary support cylinders.
Insert the new lock cylinder in the door by aligning the lock with the pin of the key cylinder.
Insert both of the screws in the lock cylinder using a Phillips #3 screwdriver.
