Introdução
If you have a short or cut power cable you should replace it with a new one. This guide will help you through replacing the power cable attached to the vacuum.
O que você precisa
Unlatch the two side clips securing the power unit assembly to the tank.
Remove the power unit assembly from the tank assembly.
Use a 3.5 mm hex key to remove the three screws securing the top cover.
Remove the top cover.
Pull out and disconnect the four spade connectors from the switch module.
Use a Torx T15 driver to unscrew the two screws securing the metal motor bracket.
3 outras pessoas executaram este guia.
1Comentário do guia
How and where do I order a power cord? Just any power? Or a specific for shop vac.
