Ir para o conteúdo principal
Sharp PC-MM20 Keyboard Replacement
O que você precisa
  1. Sharp PC-MM20 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Make sure the laptop is powered down.
    • Remove the battery from the laptop.
    Pergunte ao FixBot
    Comentar
  2. Sharp PC-MM20 Keyboard Replacement: passo 2, imagem 1 %32
    • Close the laptop.
    • Turn the laptop so that the back is facing you.
    • There will be three screws on the back. Remove each screw by using the screw driver.
    Pergunte ao FixBot
    Comentar
  3. Sharp PC-MM20 Keyboard Replacement: passo 3, imagem 1 %32
    • Flip the laptop so that you can see the bottom.
    • Remove the screws shown in the picture.
    Pergunte ao FixBot
    Comentar
  4. Sharp PC-MM20 Keyboard Replacement: passo 4, imagem 1 %32 Sharp PC-MM20 Keyboard Replacement: passo 4, imagem 2 %32
    • Open the laptop and focus on the front of the base of the laptop.
    • Notice that there are small notches in between the two plates of the laptop. There are several slots such as this that are found across the front base of the laptop.
    • Take a flat edge and wedge it into the slot to pop it open.
    Pergunte ao FixBot
    Comentar
  5. Sharp PC-MM20 Keyboard Replacement: passo 5, imagem 1 %32 Sharp PC-MM20 Keyboard Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Once the cover is loose, it should be able to shift somewhat freely. However, there are a few more connections holding it together.
    • Use tweezers to delicately remove the flat cable that connects the keyboard to the laptop.
    • Remove the flat cable from the track pad of the laptop.
    Pergunte ao FixBot
    Comentar
  6. Sharp PC-MM20 Keyboard Replacement: passo 6, imagem 1 %32
    • Remove the top of the base from the rest of the computer.
    Pergunte ao FixBot
    Comentar
  7. Sharp PC-MM20 Keyboard Replacement: passo 7, imagem 1 %32
    • Lastly, take the old keyboard out of the base and replace it with the new keyboard.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 976
