Ir para o conteúdo principal
Sharp Aquos Crystal Screen Replacement
O que você precisa
  1. Sharp Aquos Crystal Screen Replacement, Back Panel: passo 1, imagem 1 %32 Sharp Aquos Crystal Screen Replacement, Back Panel: passo 1, imagem 2 %32 Sharp Aquos Crystal Screen Replacement, Back Panel: passo 1, imagem 3 %32
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
    Pergunte ao FixBot
    Comentar
  2. Sharp Aquos Crystal Screen Replacement, USB Port: passo 2, imagem 1 %32 Sharp Aquos Crystal Screen Replacement, USB Port: passo 2, imagem 2 %32
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Sharp Aquos Crystal Screen Replacement: passo 3, imagem 1 %32 Sharp Aquos Crystal Screen Replacement: passo 3, imagem 2 %32
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
    Pergunte ao FixBot
    Comentar
  4. Sharp Aquos Crystal Screen Replacement: passo 4, imagem 1 %32 Sharp Aquos Crystal Screen Replacement: passo 4, imagem 2 %32
    • Disconnect the wire by lifting it up with a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  5. Sharp Aquos Crystal Screen Replacement: passo 5, imagem 1 %32 Sharp Aquos Crystal Screen Replacement: passo 5, imagem 2 %32 Sharp Aquos Crystal Screen Replacement: passo 5, imagem 3 %32
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    Pergunte ao FixBot
    Comentar
  6. Sharp Aquos Crystal Screen Replacement: passo 6, imagem 1 %32
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    Pergunte ao FixBot
    Comentar
  7. Sharp Aquos Crystal Screen Replacement, Motherboard: passo 7, imagem 1 %32
    • Peel off the black pieces of tape.
    Pergunte ao FixBot
    Comentar
  8. Sharp Aquos Crystal Screen Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
    Pergunte ao FixBot
    Comentar
  9. Sharp Aquos Crystal Screen Replacement: passo 9, imagem 1 %32 Sharp Aquos Crystal Screen Replacement: passo 9, imagem 2 %32
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
    Pergunte ao FixBot
    Comentar
  10. Sharp Aquos Crystal Screen Replacement: passo 10, imagem 1 %32
    • Peel the tape off with your hands.
    Pergunte ao FixBot
    Comentar
  11. Sharp Aquos Crystal Screen Replacement: passo 11, imagem 1 %32
    • Lift the motherboard out with your hands.
    Pergunte ao FixBot
    Comentar
  12. Sharp Aquos Crystal Screen Replacement, Battery: passo 12, imagem 1 %32
    • Peel off the tape holding the battery down.
    Pergunte ao FixBot
    Comentar
  13. Sharp Aquos Crystal Screen Replacement: passo 13, imagem 1 %32 Sharp Aquos Crystal Screen Replacement: passo 13, imagem 2 %32
    • Lift the battery out with your hands.
    Pergunte ao FixBot
    Comentar
  14. Sharp Aquos Crystal Screen Replacement, Screen: passo 14, imagem 1 %32
    • Replace this component with the new one.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
1Comentário do guia
Thanks! I did it!
Matteo Favero - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 75
Ao todo: 11,204
