O que você precisa
Remove the two screws at the back of the iron.
Remove the back cover piece.
3 outras pessoas executaram este guia.
3Comentários do guia
i am trying to replace the thermal cutoff but can’s remember the wire inside how to replace
I have a constant leak in the vertical position - long after the iron is cold. The repair presented is well done. However it stopped short and doesn't get to the reservoir - thanks
Then WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAT?
That #0 Phillips screwdriver does not work on my Shark Model GI 505 steam Iron. Any other ideals on how to get the cover off. The electrical cord is bad and I need to put a new cord on it. Thanks in advance.
brucetaylor - Responder
