Ir para o conteúdo principal
Shark Rocket Professional Hose Replacement
O que você precisa
    1. Shark Rocket Professional Hose Replacement, Main Hose: passo 1, imagem 1 %32 Shark Rocket Professional Hose Replacement, Main Hose: passo 1, imagem 2 %32 Shark Rocket Professional Hose Replacement, Main Hose: passo 1, imagem 3 %32
      • Look at the Shark Rocket Professional's Extension Rod.
      • Identify where the hose connects to the main body of the vacuum.
      • Press the tabs on the sides of the connector to remove the hose.
      • You can use a long, thin object to unclog the hose.
      • If this fixes your problem, then you are finished with this guide.
      Pergunte ao FixBot
      Comentar
    2. Shark Rocket Professional Hose Replacement: passo 2, imagem 1 %32 Shark Rocket Professional Hose Replacement: passo 2, imagem 2 %32
      • Look at the vacuum handle and locate the orange button that says "Handle" with a picture of a lock.
      • Press the button and remove the handle.
      Pergunte ao FixBot
      Comentar
    3. Shark Rocket Professional Hose Replacement: passo 3, imagem 1 %32 Shark Rocket Professional Hose Replacement: passo 3, imagem 2 %32
      • Look at the vacuum handle.
      • Using a T-15 screwdriver, remove the five 15mm screws in the handle by turning them counter-clockwise.
      Pergunte ao FixBot
      Comentar
    4. Shark Rocket Professional Hose Replacement: passo 4, imagem 1 %32 Shark Rocket Professional Hose Replacement: passo 4, imagem 2 %32 Shark Rocket Professional Hose Replacement: passo 4, imagem 3 %32
      • Use a plastic opening tool to pry open the handle.
      • Don't worry if the handle sounds like it is going to break; it takes a lot of force to pull apart.
      • When popping open your handle, the small grey piece of plastic(pictured in the last frame) will fly out.
      Pergunte ao FixBot
      Comentar
    5. Shark Rocket Professional Hose Replacement: passo 5, imagem 1 %32 Shark Rocket Professional Hose Replacement: passo 5, imagem 2 %32 Shark Rocket Professional Hose Replacement: passo 5, imagem 3 %32
      • The orange plastic piece may have naturally fallen out at this point.
      • Look a your handle.
      • Using your hands, pull the tube from the nozzle of the handle.
      • The tube is soldered onto a wire connecting to the plastic orange piece inside the handle.
      • Cut this connection with wire clippers to remove and replace your tube.
      Pergunte ao FixBot
      Comentar
Conclusão
Brad Iglesia
Membro desde: 01/24/18
316 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G6, Livingston Winter 2018 Membro de Cal Poly, Team S18-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G6
4 Membros
Autoria de 15 guias
4Comentários do guia
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
Jonathan Hill - Responder Compartilhar
How do you replace the hose in the beater head
daveve2 - Responder Compartilhar
Thank you for this, this guide helped a ton.
Bradlee Johnson - Responder Compartilhar
How long does it take to answer acquestion?
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 74
Ao todo: 6,961
