Ir para o conteúdo principal
Shark Rocket HV301 Rotary Belt Replacement
O que você precisa
    1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: passo 1, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: passo 1, imagem 2 %32 Shark Rocket HV301 Rotary Belt Replacement, Rotary Brush: passo 1, imagem 3 %32
      • Flip the vacuum so the bottom base is visible.
      • Gently pry the bottom two wheels off with a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    2. Shark Rocket HV301 Rotary Belt Replacement: passo 2, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 2, imagem 2 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 2, imagem 3 %32
      • Remove five visible screws with a Phillips #2 screwdriver.
      • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Shark Rocket HV301 Rotary Belt Replacement: passo 3, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 3, imagem 2 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 3, imagem 3 %32
      • Remove plate covering the roller brush.
      Pergunte ao FixBot
      Comentar
    4. Shark Rocket HV301 Rotary Belt Replacement: passo 4, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 4, imagem 2 %32
      • Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
      Pergunte ao FixBot
      Comentar
    5. Shark Rocket HV301 Rotary Belt Replacement: passo 5, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 5, imagem 2 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 5, imagem 3 %32
      • Turn the vacuum over so the rotary brush is on the ground.
      • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
      Pergunte ao FixBot
      Comentar
    6. Shark Rocket HV301 Rotary Belt Replacement: passo 6, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 6, imagem 2 %32
      • Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
      • Proceed with removing the upper casing.
      Pergunte ao FixBot
      Comentar
    7. Shark Rocket HV301 Rotary Belt Replacement: passo 7, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 7, imagem 2 %32
      • Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
      Pergunte ao FixBot
      Comentar
    8. Shark Rocket HV301 Rotary Belt Replacement: passo 8, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 8, imagem 2 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 8, imagem 3 %32
      • Remove the rotary belt on right side of vacuum from the bearing.
      • Gently lift the casing to remove the belt and brush from the vacuum.
      Pergunte ao FixBot
      Comentar
    9. Shark Rocket HV301 Rotary Belt Replacement: passo 9, imagem 1 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 9, imagem 2 %32 Shark Rocket HV301 Rotary Belt Replacement: passo 9, imagem 3 %32
      • Gently pry off the plastic casing on both sides of rotary brush.
      • Lift the clear plastic shell from the rotary brush.
      Pergunte ao FixBot
      Comentar
    10. Shark Rocket HV301 Rotary Belt Replacement: passo 10, imagem 1 %32
      • Remove the rotary belt attached to the brush and replace it if needed.
      Pergunte ao FixBot
      Comentar
    1. Shark Rocket HV301 Rotary Belt Replacement, Rotary Belt: passo 11, imagem 1 %32
      • Replace belt if torn or damaged.
      Pergunte ao FixBot
      Comentar
Conclusão
18 outras pessoas executaram este guia.
Trey Nahhas
Membro desde: 10/06/16
848 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-5, Livingston Fall 2016 Membro de Cal Poly, Team 10-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G5
4 Membros
Autoria de 20 guias
4Comentários do guia
Where can I find the rotary belt for the Shark Duo?
oneupchallenges - Responder Compartilhar
I could not get it out without removing the brush roll motor. So I am putting it back together and I need to know if the motor has a top and bottom. What I mean is does it matter ? Thank you
Jennifer Dalton - Responder Compartilhar
Thanks for the guide it came in super handy
SYSTEM 855 - Responder Compartilhar
I just wish there were instructions on how to put the vacuum cleaner back together. I have memory issues and have a hard time going in reverse when I look at the dissembly process.
The Instructions were on the spot and even someone like me was able to disassemble the Shark Rocket.
Now to figure out how to reassemble it.
Thank you,
John
John Bartkowski - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 44
Últimos 30 dias: 195
Ao todo: 38,166
