Introdução
The motherboard is the command center for the vacuum's functions. Sometimes components on the board will come loose and require replacement. This guide will show you the steps necessary to replace the motherboard.
O que você precisa
Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
Quase terminado!
Conclusão
