Introdução
If your roller brush is clear of debris, but still won't rotate, the roller brush motor may need to be replaced. Follow these steps to remove the roller brush motor for replacement.
O que você precisa
Lift the latches on both sides of the vacuum to release the dust canister.
Remove the dust canister from the vacuum by lifting it up.
Remove the roller brush motor by carefully lifting it out of the vacuum.
Desolder the wires running to the motor from the motherboard. For details on how to desolder, visit this soldering guide.
3 outras pessoas executaram este guia.
